surface reaction
Old   August 20, 2003, 11:05
Default surface reaction
Jason
Process rate is diffusion controlled in bulk gas phase, i.e. the reaction rate of surface reaction is depending on the mass diffused into the surface. Currently I just use a very large surface reaction rate (set preexponent constant to a huge value). Is this the right way, or do you have other method? Thanks
Old   August 20, 2003, 22:01
Default Re: surface reaction
Greg Perkins
That sounds OK to me. Basically you are saying that there are no kinetic limitations and that its based on the mass flux due to diffusion through the boundary layer.
I often use such an approach for the oxidation reaction to trigger ignition in steady-state simulations.
Greg
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
particle surface reaction fkuwo FLUENT 0 August 14, 2009 11:04
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
