can I animate the dynamic simulation for process |
August 19, 2003, 12:59 |
Hi, I try to annimate the unsteady simulation of process. I found that the saved data is just the one for the final time step. How can I save all the data from initial time step to the ending time step, and how can I animate this transient results in result plot such as streamline contour. BTW, how to change the background color( reverse from black to white) in the result plot?
August 19, 2003, 15:50 |
Re: can I animate the dynamic simulation for proce
To save .cas and .dat file after a defined number of time step, you have to set the File->Save->Autosave funtion.
To create an animation, you have to use the Define->Animation function. Read the help relatively to these functions for more information. Hi ap |
August 20, 2003, 09:37 |
Hi
To change the background color to white you have to click "reverse foreground/background" when you export an image (File-hardcopy...or at animation save hardcopy...) regards MATEUS |
Display Modes | |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 14:46 |
openFoam for fire dynamic simulation | hadi1982 | OpenFOAM | 2 | November 2, 2009 06:30 |
dynamic stall simulation over an airfoil | mleahy | FLUENT | 0 | October 9, 2009 13:15 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
