how to do a good meshing using unstructured mesh |
August 1, 2003, 00:20 |
hello friends,,it seems that i have a problem in meshing since my grid check is always failed.my model is an aircraft which the flow around it..what is the good meshing, i mean what kind of size of meshing that is suitable for my model size:625mm..pls advise
August 1, 2003, 06:03 |
Re: how to do a good meshing using unstructured me
There are several answers to your question. Here are some of them:
Create a grid who's density is smaller than the smallest flow structures you wish to capture. Start with a coarse grid and use the FLUENT adapt function to resolve in area of high variable gradient. Although care is needed to ensure the grid is not too coarse to not pick up high variable gradients in the first place and so will have do data to adapt to. Conduct a grid independance study. This is where you run a simulation with a coarse grid, then refine the grid and run the same simulation and examine the differance in the results. Continue to do this until the results do not alter with incrasing grid density. At this point the simulation is said to be "grid idependant" |
August 1, 2003, 06:19 |
tq andrew for your good explaination.i just do what u have suggested.but i stil have a problem, i create 2 domains in order to minimise the element number in grid..but then, when i mesh the big domain after i mesh the small domain, the check grid is always failed.If i just mesh small domain, then check grid is done....why then??pls advise
August 1, 2003, 07:57 |
I am not sure why your grid check is failing. What criteria is it failing on? If the grids are the same, it should not matter which is meshed first as this data is not exported to fluent from gambit.
August 2, 2003, 02:45 |
check grid failed because of non-positive face area exist...how to overcome this since i redo meshing many times..but then..the same warning still appear..pls advise
August 13, 2003, 03:04 |
there is a website, a tutorial of airfoil. maybe useful to you.
http://instruct1.cit.cornell.edu/cou...foil/step1.htm |
August 22, 2003, 21:06 |
Nikita,
If you still have problem just send me the geometry file ( iges, step or parasolid ) and I will try to mesh it and tell you where is the problem. Jim |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
ANSYS Meshing Mem Usage Seems High for 7 million Element Mesh | jonny_b | ANSYS Meshing & Geometry | 2 | August 15, 2011 08:39 |
What's the correct unstructured mesh procedure | Nick R | ANSYS Meshing & Geometry | 3 | January 12, 2011 18:40 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
