August 18, 2003, 07:35 |
problem with interfaces
Please help me! I defined grid interfaces and but during initialization fluent print such a error " Unassigned interfaces in interface zone 5 " what's going on? what i should do to start initialisation and to continue computation? regards
August 19, 2003, 05:02 |
Re: problem with interfaces
You must define the grid interface in Fluent with Define/Grid interfaces... I assume that your grid interfaces are boundaries, done in some mesh generating program?
Regards |
August 19, 2003, 10:31 |
Could you write me some detail about your problem ans mesh zones. Are they of same size ? Rahul
August 20, 2003, 04:52 |
u must define your interface in GAMBIT or ICEM ... before u import your grid to fluent.
August 25, 2003, 17:03 |
this is a problem of windows platform.....but works fine on unix platform. grid interfaces need not be defined beforehand in gambit or icem. also , fluent sent me some text command which I used before creating the interface, then it worked... sandeep
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Problem with Domain Interfaces | hagupta | CFX | 13 | May 5, 2006 12:41 |
