September 4, 2003, 04:24 |
Add New Material
Very strange! I follow the step of ug "creating a new material" and it just won't work. Can not be added into the list. Can anyone tell me why? Thanks.
DAVIS |
September 4, 2003, 06:51 |
Re: Add New Material
To create a new material, go to Define->Materials...
Then 1) Insert the name of the new material. 2) Choose material type (fluid - solid) 3) Insert (optional) the chemical formula. 4) Define all properties of the new material. 5) Click on change-create. The new material will be added to the Solid Materials drop down list if you defined a solid material or to the Fluid Material drop down list if you defined a fluid material. Hi ap |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
How can I add new material? | doctoryk | STAR-CCM+ | 2 | May 11, 2010 15:13 |
How to add more material properties | sarahsun | CFX | 1 | October 27, 2009 07:27 |
How to use User defined database to add material | sangeeta | FLUENT | 1 | February 25, 2009 13:02 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
