September 24, 2003, 06:36 |
Air humidity modelling
Dear.... How to model air humidity in room in segregrate solver? Thank very much T_T Help me pls.
September 25, 2003, 04:39 |
Re: Air humidity modelling
You can use the VOF model, but I am uncertain how accurate it will be. You will have define two phases. The primary phase is air, and the secondary phase is water vapor. But I'm not sure how you can dipserse the water vapor in the air.
September 25, 2003, 07:16 |
Hey, I do not know what is the importance of using a seggregated solver for you. According to me you should create a Scalar (UDS) corresponding to the air humidity fraction throught the domain. Like that this scalar will be transport through out your domain. In that case the mixture model is one of the solution possible. Now maybe Fluent already takes into account air humidity transport in a multiphase model, you should check. Hope this help thomas
September 25, 2003, 10:03 |
The important of using seggregrated solver because I familiar with this solver than others.
Thank you very much for your (2) answers I'll tryyyyyy |
September 25, 2003, 14:51 |
Hi, Air humidity can be processed by solving the species transport equations, you dont need to go to multiphase models. If youre looking for predicted mean vote or predicted percent dissatisfied, you should explicitly write them. Regards emre
October 16, 2003, 04:10 |
Hi, for a humidity model I tried with 2 speces: air and water vapour. You define allways your properties as fonctions of the mass fraction and I assure you that it works. I validate this kind of model by experimental data. good luck!
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Modelling an air filter | siw | CFX | 5 | September 13, 2011 12:48 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Air bearing modelling | Dave Larkham | CFX | 1 | October 19, 2008 19:10 |
Modelling air flow around a sphere | Fergie | FLUENT | 1 | December 5, 2005 15:27 |
