November 11, 2003, 05:18 |
Journal command to patch values
I would like to run fluent in batch mode, therefore I have to write the journal file, however, I could not find journal command to patch values to particular cells where is the corresponding command to the following panel solve->initialize->patch I am using VOF model. thanks |
November 11, 2003, 05:20 |
Re: Journal command to patch values
The solve initialize set-default mp-1 1 will set the value for the whole domain. it is suppose to set the value for the second volume.
November 11, 2003, 06:55 |
You have to use a scheme tool inside your journal file. You can get it at www.fluentusers.com It worked for me.
November 11, 2003, 09:53 |
Hi, Just a suggestion: don't you think patching your values through the GUI - save the .dat file - and then run fluent in a batch mode by calling this .dat file could be an alternative to your problem.
thomas |
November 11, 2003, 10:07 |
Thanks, I just realised this maybe a better option. Just thought that the GUI panel should have a text command.Fluent recorded journal file still requires the GUI to run!
November 11, 2003, 10:11 |
Hi, excuse me what do you mean by 'Fluent recorded journal file still requires the GUI to run' ? . You can use fluent and your journal file from a shell script command. However concerning the set-up ( choice of model, parameter ect ect ) obviously the GUI is more than helpful . regards thomas
November 11, 2003, 10:27 |
Journal files automatically saved by Fluent contain commands that operate directly on the GUI, like
(cx-do-gui cx-activate-item "MenuBar*WriteSubMenu*Stop Journal") therefor GUI needs to be activated to use this file. Is this the case? Regards, Wenbin |
November 11, 2003, 10:36 |
As far as I know, using fluent batch means running fluent without using the Graphic User Interface. In that case you use this command: fluent 2/3d -g <Journal-name>& results.txt Now about a journal file automatically generated by fluent, I think you know more than me about this so I won't get into that field wihtout knowing. But I also know that a journal file can effectively be launched from the GUI, but in that case you are not in batch mode anymore. thomas
November 11, 2003, 13:10 |
#9 |
greetings,
the latest released version of FLUENT, v6.1.22, has the "patch" command in the text-user interface (tui) under solve/patch this tui command was missing in earlier versions. regards, eric. |
OF 1.6-ext setFields does not keep patch values | Arnoldinho | OpenFOAM Bugs | 3 | May 9, 2012 03:58 |
simpleSRFoam, makePatch and cyclic patch | vaina74 | OpenFOAM Running, Solving & CFD | 7 | February 28, 2011 07:26 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 23, 2001 23:16 |
