Effect of flow rate (reyold number) on swirl flow drying |
August 26, 2015, 03:09 |
Melvin Emil Simanjuntak
I made simulation in ansys 15.0 for eulerian-lagrangian, multi component, injection for swirl coal drying. Some variation of parameters perform in this simulation. Especially variation of air dryer flow rate (reynold number), I get difference trend, where drying process become slower if I increase the air dryer flow rate (reynold number). of course it should have been faster if we add air dryer or increase reynold number of air dryer (based on experimental or equation heat and mass transfer). Did somebody know what must be setting to meet the trend???
Thanks |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 10:30 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
How to calculate phase flow rate? | sangramroy | FLUENT | 0 | January 11, 2012 13:02 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
