Journal command to patch values
Old   November 11, 2003, 05:18
Default Journal command to patch values
Wenbin
I would like to run fluent in batch mode, therefore I have to write the journal file, however, I could not find journal command to patch values to particular cells
where is the corresponding command to the following panel
solve->initialize->patch
I am using VOF model.
thanks
Old   November 11, 2003, 05:20
Default Re: Journal command to patch values
Wenbin
The solve initialize set-default mp-1 1 will set the value for the whole domain. it is suppose to set the value for the second volume.
Old   November 11, 2003, 06:55
Jonas
You have to use a scheme tool inside your journal file. You can get it at www.fluentusers.com It worked for me.
Old   November 11, 2003, 09:53
thomas
Hi, Just a suggestion: don't you think patching your values through the GUI - save the .dat file - and then run fluent in a batch mode by calling this .dat file could be an alternative to your problem.
thomas
Old   November 11, 2003, 10:07
Wenbin
Thanks, I just realised this maybe a better option. Just thought that the GUI panel should have a text command.Fluent recorded journal file still requires the GUI to run!
Old   November 11, 2003, 10:11
thomas
Hi, excuse me what do you mean by 'Fluent recorded journal file still requires the GUI to run' ? . You can use fluent and your journal file from a shell script command. However concerning the set-up ( choice of model, parameter ect ect ) obviously the GUI is more than helpful . regards thomas
Old   November 11, 2003, 10:27
Wenbin
Journal files automatically saved by Fluent contain commands that operate directly on the GUI, like
(cx-do-gui cx-activate-item "MenuBar*WriteSubMenu*Stop Journal")
therefor GUI needs to be activated to use this file.
Is this the case?
Regards, Wenbin
Old   November 11, 2003, 10:36
thomas
As far as I know, using fluent batch means running fluent without using the Graphic User Interface. In that case you use this command: fluent 2/3d -g <Journal-name>& results.txt Now about a journal file automatically generated by fluent, I think you know more than me about this so I won't get into that field wihtout knowing. But I also know that a journal file can effectively be launched from the GUI, but in that case you are not in batch mode anymore. thomas
Old   November 11, 2003, 13:10
eric
greetings,
the latest released version of FLUENT, v6.1.22, has the "patch" command in the text-user interface (tui) under
solve/patch
this tui command was missing in earlier versions.
regards, eric.
OF 1.6-ext setFields does not keep patch values Arnoldinho OpenFOAM Bugs 3 May 9, 2012 03:58
simpleSRFoam, makePatch and cyclic patch vaina74 OpenFOAM Running, Solving & CFD 7 February 28, 2011 07:26
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
