Boundary problem
Old   November 13, 2003, 06:25
Default Boundary problem
eric
I have an inlet on a box for which i have no boundary conditions. The inlet is just below a flame so that air is being sucked into the system from this inlet. What inlet boundary condition should i use.
I would like to use an outflow boundary at the outlet to the system and this means i cannot use a pressure inlet boundary at the inlet. Is there a way around this?
Can i set the inlet as a pressure outlet, is that appropriate?
Regards
Eric
Old   November 18, 2003, 20:48
Default Re: Boundary problem
Alamgir
Your idea doesn't match coz when u set outlet as a boundary condition air will not be sucked anyway. I recken to set a fan as boundary condition.... that will blow air into the firebox as it needs.
Alamgir
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 09:28
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
Boundary layer meshing problem in Gambit Crystal Main CFD Forum 0 June 12, 2009 14:32
problem boundary profiles Rainy FLUENT 0 April 24, 2008 05:30
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 02:02
