November 12, 2003, 05:01 |
Pre-heat combustion air
I want to investigate the effect of pre-heating the combustion air to a burner. I'm doing this by simulating a system with an inlet velocity , calculated from a known mass flow rate, for stiochiometric conditions and then simulating the same system for stoichiometric conditions with the pre-heated combustion air. If the air is pre-heated there is a density change that in turn causes an increase in velocity if the mass flow rate must remain the same, I'm sure this correct?? So how do you tell the difference between the effect the preheat has on the flow and the effect the increased velocity has on the flow????? Or can the velocity be kept constant?? Please help really stuck!! Regards, Eric |
November 17, 2003, 11:36 |
Re: Pre-heat combustion air
Of course the velocity increases when you use preheated air for a given liberation rate, you still need the same amount of oxygen for cmoplete combustion.
The change in your flame shape/quality is indeed effected by both air speed and temperature, my guess is that the temperature is more important. |
Heat transfer from air to solid | Tramph | FLUENT | 0 | January 25, 2011 17:42 |
Air for combustion | AdidaKK | Main CFD Forum | 0 | December 16, 2009 17:20 |
heat transfer - heating element to air in FloWorks | Duncan Gravill | Main CFD Forum | 1 | March 28, 2007 20:16 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Heat emitted by combustion products | Mark | FLUENT | 0 | April 21, 2004 07:59 |
