large model problems
Old   November 19, 2003, 04:39
Default large model problems
Lars Andersson
We are trying to run a 70 million cell model. The .msh can be read into fluent, after writing down the .cas it can not be read into fluent. Also we have seen that it takes extremely long time to read and write down large models (30 millions) in parallel. Has anybody some idea regarding these problems ?
Old   November 19, 2003, 13:00
Default Re: large model problems
Erwin
Yup. Takes extremely long. My 3 million cell problems take between 1 and 2 hours to read onto a parallel machine. There is an rpsetvar command to speed up the communication but this will lead to a crash, tested it several times.
I guess that now people will go more and more to larger problems on parallel machines, Fluent will really have to address this issue!
Old   November 25, 2003, 00:41
Casey
I have run a 31 million cell simulation before. Read in and write out time will depend on the machines you are using, but my read in time is about 6 hours for case and data on two Sun Ultra Enterprise 6500 machines using 36 cpu's. As for the error on read in, I have no idea from the information provided. Maybe someone could help if you gave the error you are receiving? Good Luck, Casey
non-linear k-epsilon model implementation problems Saidi Main CFD Forum 2 March 4, 2010 13:23
Problems with Unsteady simulations using LRR Model in transientSimpleFoam barath.ezhilan OpenFOAM Running, Solving & CFD 1 July 25, 2009 13:58
multiphase cfd model problems zhijing peng FLUENT 0 January 7, 2009 13:07
Convergence problems with SSG turbulence model Ram CFX 1 June 19, 2006 10:08
Search of large problems Rashid Faizullin Main CFD Forum 0 September 10, 1998 13:46
