soil surrounding
Old   November 18, 2003, 07:14
Default soil surrounding
Leila
Hello everybody I forgot to state that the pipe I should model transient natural gas flow in, is buried under the ground and I should also model heat transfer . So there exists three layers, i.e a gas layer bounded by the pipe and the soil surronding the pipe. Can I model heat transfer in this problem while modeling mass transfer? Please help me. Thanks
Old   November 27, 2003, 02:44
Default Re: soil surrounding
ccc
hi Leila,
Fluent can model conduction in solids. you should have three seperated zones in your model, a fluid zone for gas and two solid zones for pipe and soil, respectively. Do not forget to give properties of gas, pipe and soil in the material panel.
good luck.
Soil and Internal Water Pressures mattyg88 ANSYS 1 March 13, 2010 11:45
Surrounding cells of a node gemini Fluent UDF and Scheme Programming 8 July 4, 2009 14:54
How to access surrounding variables? chemycc CFX 0 April 30, 2009 01:42
soil -pile arun3248 ANSYS 1 March 25, 2009 23:51
Blast effect on soil. Donald Hawken Main CFD Forum 0 June 18, 2001 14:21
