Two UDF's
Old   December 3, 2003, 09:07
Default Two UDF's
Dimitrios
Hi there ladies and gents....
I have a problem here....I'm planning to use two UDF's, one for variable mass flux and one for dynamic meshing. How do I use the results from UDF1 to UDF2?
Old   December 3, 2003, 17:02
Default Re: Two UDF's
Ajay Rao
You could have everything in one C file. Declare varaibles as GLOBAL varaibles so that all your macros/ functions can "see" them. -Ajay
Old   December 4, 2003, 02:38
Dimitrios
That sounds like a good idea....
Old   December 4, 2003, 04:34
Andrew Garrard
That is what I would have suggested, althogh the alternative is to dump variables in a UMD and these can be passed between c files
Old   December 4, 2003, 05:09
emma
But what does "UMD" mean?
Regards,
emma
Old   December 4, 2003, 05:14
Andrew Garrard
Sorry - That I meant UDM, user defined memory, that was a typo.
here is some info: http://www.fluentusers.com/fluent61/...e107.htm#23772
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 04:31
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 17:18
Unsteady and Flux UDFs for UDSs tom FLUENT 0 February 13, 2009 10:27
Multiple UDFs Graeme FLUENT 4 August 28, 2004 15:47
Experimental Repository for UDFs, Journal Files and Scheme Scripts Jonas Larsson FLUENT 0 March 5, 2000 15:36
