Heat Flux from warm water ...
Old   December 5, 2003, 20:48
Default Heat Flux from warm water ...
David
Dear users ... Model : pipe 18/16 mm. Inside is runing warm water with 90 degrees of Celsius.On the pipe is metal sheet with 0,2 mm thicnkess. I would like to simulate charakteristic of temperature to distance from surface pipe-metal sheet. Problem : I don't know, what kind of boundary conditions are metal sheet, pipe. I solved this was : (2D) Pipe is "wall" with heat flux about 70 W/m2, 340 K, thickness 1 mm, material (Cu) with constant thermal conductivity. Metal sheet is "solid" with initialize temperature about 395 K. After starting iterate, iterating finished in 5. steps like convegency solution. Then Fluent tell me any error in file, which is compile in C (I mean C++) Please, advise me with this problem Thank you!
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
heat flux distribution gtheo CFX 2 April 27, 2011 03:36
CFX - wall heat flux divarano CFX 2 December 4, 2006 16:14
monitoring dynamic heat flux through a surface abdnakhi FLUENT 0 August 15, 2005 09:57
Wall heat flux cujo CFX 3 November 6, 2002 03:43
