The boundary condition for the countercurrent |
November 23, 2004, 03:00 |
Hi There are two kind fluids (liquid and gas) in my system and the system is the countercurrent. The gas phase inputs at the bottom boundary of the geometer and leaves at the top boundary. The liquid inputs at the top boundary and leaves at the bottom.
Question 1 If the top bounady is set the inlet, can i use UDF to interpret that the gas phase can pass through the top boundary ? What macros I need use ? Question 2 If the bottom boundary is set the outlet, can i use UDF to restrict that the gas phase can't pass through the bottom boundary but the liquid can pass ? What macros I need use ? thank you |
April 11, 2011, 20:59 |
Fredy Cabrales
Rep Power: 16 |
Hi Gali!
were you able to set up the boundary conditions for your simulation? I am having the same problem as you. I really appreciate your help. |
September 2, 2011, 08:22 |
Question
If both of you resolved this problem please shere it with me. I have the same problem. Thanh you in advance.
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Can anyone give me some hint on how to make traction free boundary condition? | poplar | OpenFOAM | 3 | January 14, 2015 02:37 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
