Influence of relaxation factor on the final result |
December 25, 2003, 22:16 |
I am computing a turbulent flow field using standard k-epsilon model with source terms added to the momentum equations. My problem is that it converge only when I reduced the relaxation factors of continuity and momentum equations. I want to know whether too small relaxation factors,like 0.05,will affect the final physical results.
December 26, 2003, 08:18 |
Re: Influence of relaxation factor on the final re
OH!It's false convergence!I've just examined the residual fields,it's still large for the momentum equation.
December 26, 2003, 18:03 |
You can either speed up to the solution fast or slow depending on the value of relaxation parameter. If you use high value it would want to reach the final value fast, but sometime could diverge the solution. Special cases you have to see what's happening to the solution. You can flip the relax. parameters for pressure and momentum to converge fast, may work sometimes....
December 26, 2003, 21:38 |
Thank you,Ashu!I'll try it.
December 27, 2003, 10:32 |
they have no influence on results
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
