minimum volume
Old   December 26, 2003, 21:04
Default minimum volume
co2
When you do grid check what if you get a negative volume ? is that ok ? what does a negative volume mean?
minimum volume (m3): -2.782189e-01
Old   December 28, 2003, 11:39
Default Re: minimum volume
ashu
Negative volume is not okay... Fluent will not solve... if you have cells (tets) in complex geometry the most skewed element could have this problem that doesn't pass the mesh check....Try modifying mesh to remove the negative volume cells....left-handed cells will also result in negative volume... These are connectivity issues between adjacent cells as per fluent definition...
Old   January 1, 2004, 04:35
sijal ahmed
negative volume are not ok, as they produce the singularity . it can be check by eyes. generally this problem is near the solid body with converging section. wat happens is that the two or more mesh lines at wrong path
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
