January 9, 2004, 00:27 |
constant Heat flux at the wall
I have a 3D geometry, for which i have to calculate Nusselt number using constant Heat flux at the wall throughout the length of the tube. Can i use the FLUENT funcion
Boundary conditions --- wall ----- heat flux or i have to write some UDF for this. |
January 9, 2004, 04:45 |
Re: constant Heat flux at the wall
If you wish to simulate a heat flux that is constant with time, and position on the wall, then you can use default FLUENT function. UDF's are used to create variable, functionally dependant boundary conditions.
January 9, 2004, 07:13 |
Thanks Andrew
Display Modes | |
How to set a initial temperature and constant heat flux at same BC's?? | Jane | FLUENT | 4 | October 25, 2015 12:01 |
Heat Flux Wall Boundary Confusion. | Joee | FLUENT | 1 | August 21, 2010 12:20 |
wall heat flux | Sangeeta | FLUENT | 0 | May 7, 2009 02:22 |
Wall Heat Flux Boundaries conditions | Abigail | FLUENT | 2 | July 24, 2007 09:34 |
Constant heat flux | ocy | FLUENT | 1 | January 17, 2005 01:54 |
