cell heights in a 3D model
Old   December 18, 2003, 02:58
Default cell heights in a 3D model
Sarkar
I have a fairly complicated 3D geometry and the meshing was very complicated (involved hex+tet elements). Now I have a few hundred thousand cells, and I need to know the dimension of each cell in a particular direction (for example, height h in z direction) for another analysis. How can I get these numbers? Is there any direct or indirect way to extract the cell height information from FLUENT (or GAMBIT). Any suggestion will be highly appreciated! Thanks in advance. S.S.
Old   January 5, 2004, 03:59
Default Re: cell heights in a 3D model
sijal ahmed
i think u can do it by seeing the countors of gird or by surface intergral panel. write back if it works
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
Own turbulence model: cell loop bastil OpenFOAM Programming & Development 0 April 7, 2010 17:25
Warning 097- AB Siemens 6 November 15, 2004 04:41
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
