Problem with surface pressure integrals
Old   February 9, 2004, 15:09
Default Problem with surface pressure integrals
javier
Hello: I work with sails, and i use it as parachute. I think in this case all the force over the surface must be from viscous terms ( no too much ciculation arround the sail appear), but when i make a force report the viscous force is very smaller than the pressure force. Does anyone knows why?
Other problem is that the pressure force on the sail and the sail shadow are of the same direction, and i think they must pe opossite.
When this problem appear i put a wall in a down stream inviscid flow, and the Dalambert paradox doesnt appear, There was force!. There are too many things i dont understand. Can anyone help me please?
Thanks
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
a problem in calculating pressure drop in Fluent? yu chun FLUENT 1 May 18, 2004 03:40
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
