February 6, 2004, 07:03 |
Influence of Y+ value
I am applying Standard wall function in my simulation. After the first try, I found Y+ values in some regions were out of the range of 30-60. Then I adapted the near wall grid with Y+ adaption (min. 30 and max. 60). The cell number increased by around 3000 after adaptation. Then I iterated again until convergence was obtained. But when I compared the velocity distribution between these two runs, it showed only negligible difference. Is this possible or I am doing anything wrong? Thanks for all your opions.
February 6, 2004, 13:02 |
Re: Influence of Y+ value
Did you look near-wall or mean flow profile? I think, if you look near-wall by a log-scale, you will see the difference...
Regards |
February 6, 2004, 19:27 |
February 6, 2004, 19:31 |
Thank you very much. I will look into the near wall carefully.
Gravity (g) Influence on Simulation Results | Colin | FLUENT | 12 | September 23, 2015 09:45 |
Region on influence in ansys meshing | ATOTA | ANSYS Meshing & Geometry | 0 | November 17, 2010 15:31 |
influence of the hydrostatic pressure | pdz711 | FLUENT | 0 | June 16, 2008 03:38 |
influence clogging in porous media | budiharto | FLUENT | 0 | July 27, 2005 09:06 |
Gravity g's influence on Simulation Results | Colin | Main CFD Forum | 6 | November 2, 2003 14:13 |
