vertical pipe
Old   February 8, 2004, 08:08
Default vertical pipe
A.Naser
* Any one have a ready geometry for a vertical pipe?
* Is there any ability to let the axis in the middle. i.e. not at the pipe wall?
* Is any one try or know how to simulate an oil well annulas?
Old   February 8, 2004, 14:21
Default Re: vertical pipe
ap
Not sure what you need. A vertical pipe? It should be a simple cylinder, which you can create and mesh in few minutes using GAMBIT.
GAMBIT 2 or following creates cylinders and solids geometries with the axis in the center of the geometry, so you shouldn't have this problem. Anyway, you can translate the cylinder to put it's axis where you want.
Hi
ap
two phase air-water vertical pipe hasan-hasani FLUENT 3 March 25, 2009 03:53
energy conservation in vertical pipe Atit Koonsrisuk CFX 1 March 30, 2005 11:41
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
vertical pipe flow sanjib das sharma CFX 2 July 30, 2001 06:17
