FLUENT doesn´t work !
Old   February 10, 2004, 07:09
Default FLUENT doesn´t work !
javier
Hello: I work with sails, and i use it as parachute. I think in this case all the force over the surface must be from viscous terms ( no too much ciculation arround the sail appear), but when i make a force report the viscous force is very smaller than the pressure force. Does anyone knows why?
Other problem is that the pressure force on the sail and the sail shadow are of the same direction, and i think they must pe opossite.
When this problem appear i put a wall in a down stream inviscid flow, and the Dalambert paradox doesnt appear, There was force!. There are too many things i dont understand. Can anyone help me please?
Thanks
Old   February 24, 2004, 12:57
Default Re: FLUENT doesn´t work !
K. Kevala
The dpm model has a minimum diameter for particles, I believe 1e-8 m. Try setting your particle size to 2e-8. If not acceptable for your model, I suggest contacting Fluent, there may be something you can change in a header file to decrease the minimum diameter.
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
udf fluent 6.3.26 don't work in fluent 12 enry Fluent UDF and Scheme Programming 16 September 9, 2010 02:44
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
How does Fluent RANS model work? Tang Jingwei FLUENT 6 August 22, 2009 15:08
Fluent does not work on openSUSE 11.0 Stanislav Sviderek FLUENT 1 July 28, 2008 17:21
