How to define dynamic mesh model B.C using Profile
Old   February 12, 2004, 08:37
Default How to define dynamic mesh model B.C using Profile
David
I want to simulate a beam vibration acted by wind using dynamic mesh model. It needs to define dynamic boundary conditions, on which the nodes' velocity calculated from the external program. I don't know how to define this B.C. using the Profile in Fluent. My problem is urgent, any suggestion will be great appreciated. Thanks.
Old   February 12, 2004, 09:00
Default Re: How to define dynamic mesh model B.C using Pro
David
I defined the Profile like this format in Fluent UG:
((velocity-prof point 8)
(x
4.00000E+00 4.00000E+00 4.00000E+00 4.00000E+00
4.00000E+00 4.00000E+00 4.00000E+00 4.00000E+00 )
(y
1.06443E-03 3.19485E-03 5.33020E-03 7.47418E-03
2.90494E-01 3.31222E-01 3.84519E-01 4.57471E-01 )
(u
5.47866E+00 6.59870E+00 7.05731E+00 7.40079E+00
1.01674E+01 1.01656E+01 1.01637E+01 1.01616E+01 )
I choose "User Defined" mesh motion style using this Profile, but Fluent prompts me:
"incorrect cg motion udf f1velocity-prof on zone 5 (assuming no motion)"
what's wrong ?
Old   February 13, 2004, 09:56
David
I wrote a UDF to solve this problem based on the example of DEFINE_GRID_MOTION() macro. In this example,I found there were several macros that Fluent have not explicitly explained in its Documentation. Why does Fluent not put them into the macros list in the help file and give detail?
Old   February 18, 2004, 16:57
Cfdtoy
Hi David
Came across your discussions.
IF I would wanna make a wall move "into the fluid and away from the fluid " with a given frequency and amplitude..could you help me with a UDF for the same ?
Working with the help files from Fluent, I experienced a problem in Meshing Error..like it said.."non-positive Volumes exist"..does the tutorial problem...work fine with you ?
Thanks
CFDtoy..
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Dynamic mesh model for swimming torpedo FLUENT 0 February 25, 2009 04:05
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 02:37
problem about dynamic mesh of VOF model whpsoft FLUENT 0 September 8, 2005 23:06
How to define Dynamic Mesh boundary condition? David FLUENT 0 February 11, 2004 08:48
