flow around a plate- Negative absolute pressure???
Old   March 14, 2004, 08:44
Default flow around a plate- Negative absolute pressure???
tania
I want to model a flow around a plate (Length 100mm and width 3mm) in a domain (Length 1000mm, and width400 mm). As a boundary conditions, I put a velocity inlet and mass outflow. and I kept the operating pressure as atmospheric pressure.
For low velocities (1m/s, 3 m/s), the results seem to be good but for higher inlet velocities (8m/s) I got NEGATIVE absolute pressure??? can someone help me with this????
Thanking you in advance .
Tania.
total pressure change in a pipe flow Im FLUENT 5 February 23, 2017 08:55
absolute negative pressure???? john Siemens 6 December 12, 2014 00:18
Positive Pressure ang negative Pressure moca CFX 3 September 18, 2010 06:00
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
avoiding negative absolute pressure!!! Tania FLUENT 8 March 30, 2004 18:41
