March 18, 2004, 06:11 |
Fluent grid file format
Does anybody have any idea about where to get details of fluent 6.x grid file formats. i wish to read fluent file into my application (some code I am writing).
March 18, 2004, 07:09 |
Re: Fluent grid file format
Hi!
What you should do is: go to "surface-iso surface". Then set surface of constant density - set iso values to desired density for example 500kg/m^3 if you have water air problem. This defines a line of cnstant density (the line of interface). Chose the name for the surface, for example denity500 and click create. To get the coordinates go to "plot-xy plot". Deselect "position on x axis". set "Y axis function to grid - y coordinate" and "x axis function to grid x coordinate. Select "density500" at surfaces. If you want to get the numerical values (instead of plot) select "write to file".. Hope this helps... MATEUS |
March 18, 2004, 07:14 |
Sorry this was the answer to some other question...
mateus |
March 19, 2004, 08:56 |
I remember the GAMBIT manual explains the neutral format for mesh and the FLUENT user manual explains the fluent native format.
Just check it out. |
March 20, 2004, 05:37 |
thanks, i could locate that in fluent manuals, its given where they explain cas-data file formats.
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
Importable grid file format for cfx 5.71 | Oliver | CFX | 4 | March 30, 2006 11:40 |
