DPM setting of Time Scale Constant
Old   March 15, 2004, 08:14
Default DPM setting of Time Scale Constant
Christian
Hi.
The Time Scale Constant or the C_L is default 0.15 for the K-e turbulence model.
If one sets this to 0.015, the particle pattern is much less turbulent. The manual says that this constant is not well known, but the solution is very sensitive to the parameter. Does anyone know how to choose this value, or know of any references. And what do You do. Just use the default value or???
Christian
Old   March 19, 2004, 18:38
Default Re: DPM setting of Time Scale Constant
David
from what i read it is better to keep it this way. better use the default value
regards
David
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 14:20
