March 24, 2004, 16:20 |
Fluent question
Hi, I wanna simulate the flow in a 3d square duct (aspect ratio=1) with a cylinder hanging in the duct by a line. the flow is incompressible which is actually issuing from a ventilation fan. In this case, what kind of mesh I should use? Is the side wall boundary layer of the duct important? Many thanks.
Jane |
March 25, 2004, 06:53 |
Re: Fluent question
That depends on your Re, Jane...is it laminar or turbulent flow? have you done a dimensionless analysis of the case?
March 25, 2004, 08:04 |
Re: Fluent question
Hi, The side of the duct will certainly have a low influence compare to the front side. However it could interesting to study it. The important part of your mesh has to the boundary layer. Depending on which near wall law you are using you need to decide what Y+ you want, and this will give the size of your boundary layer (or at least the first cell range size). For the rest, make sure your domain is enougth big to let the post-duct instabilities get fully developped.
Bye, Thomas |
Question about modeling an elastic wall in Fluent | Mosheraa | FLUENT | 2 | June 24, 2011 18:47 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Question: BC openFOAM vs. FLUENT | oehmu | OpenFOAM | 2 | December 14, 2010 16:14 |
a question about the liquidus temperature in fluent | hunter | FLUENT | 0 | April 13, 2009 21:55 |
General question regarding Fluent 6.3s mesh motion | AndyRoth | FLUENT | 0 | December 8, 2006 12:01 |
