mesh adaption memory limit
Old   March 26, 2004, 04:35
Default mesh adaption memory limit
Dave
I seem to have reached the limit of mesh adaption, I can adapt by any parameter 2 or 3 times, but if I try to adapt further the following error message occurs:
Warning: ST_Realloc: out of memory. Error: Resize_Storage_On_Thread: Out of memory. Error Object: ()
The machine has 4 GB of hard memory and the virtual memory has been set to its maximum.
Is this a limit of physical memory whereby an increase would solve the problem, or is there a set limit within Fluent of the number of cells that can be used? Thanks.
Old   March 27, 2004, 09:02
Default Re: mesh adaption memory limit
David
hi,
i have encountered the same problem. Maybe it is due to the fact that the gradient where you want to define your region adaption is so steep compared to the rest of the region that Fluent needs to increase its number of cells drastically to be able to follow on this.
Even though there is the error message you can see the number of cells the adaptive function has created by going through grid->check and you will see how much it has increased.
Remember that you can use around 100 000 cells for 100 MB of RAM. So with 4 GB you can use 4 millions cells.
i hope this helps
David
David
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
Mesh Mignard FLUENT 2 March 22, 2000 05:12
