March 15, 2004, 13:27 |
Drag Coefficient
Hello!
How can I determinate the aerodynamics coefficients(drag and lift) in a two-dimensional and three-dimensional body in Fluent 6.0? Cheers António Nery |
March 15, 2004, 16:57 |
Re: Drag Coefficient
In the menu Solve>Monitors>Force... you can select what coefficients do you want to report and how to do it: in the screen, in a file (with the name specificated where "c.-history" is showed), in a graphic, or combined.
March 16, 2004, 03:37 |
Hi!
If you want just the converged values go to the "report-forces" and print them. best regards MATEUS |
March 30, 2004, 10:03 |
I also used the same way like toutorial to slove the external flow of truck. But I can'nt get the right answer about drag coefficient (Cd<1). My case is 3d and unstructure mesh. Finally I got Cd using custom field function. I can'nt make sure that this is a right answer.
Drag Coefficient Convergence Problem | John | FLUENT | 18 | June 24, 2023 09:22 |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
Drag coefficient for parcels in dieselFoam | sebastian_vogl | OpenFOAM Running, Solving & CFD | 5 | December 31, 2008 12:19 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
