ERROR message
does anyone know what this error message means and what should be done to solve it? Error: floating point exception (imprecise) Error Object: #f thank you in advance David |
ERROR message
I forgot to mention it occurs when i add a pdf file for non premixed combustion.
thank you David |
ERROR MESSAGE
Does anyone have an answer to my question?
It happens when i add the pdf file for non premixed combustion only on parallel processing. I use FLuent 6.1.18, does anyone have an answer to my problem? thank you very much David |
Re: ERROR MESSAGE
Never happened to me, but why don't you update to Fluent 6.1.22 and see if it helps... Good luck!
Re: ERROR MESSAGE
The problem was due to an error in the pdf file. The temperature values were extremely high.
that's why!! |
