Problem about interpreted UDF
Old   April 8, 2004, 00:44
Default Problem about interpreted UDF
Earng
I already have case and UDF files but when i interpreted them,the error was happen. It informed that "error: udf compiler: cannot execute cpp". What does it mean and how to solve this problem.
Old   April 8, 2004, 05:16
Default Re: Problem about interpreted UDF
ap
FLUENT have a C interpreter, not a CPP interpreter, so try to change the file extension from CPP to C and don't use CPP commands in your interpreter UDF.
Hi
ap
Old   April 8, 2004, 05:35
Earng
Thank you for your suggestion. It means that I must use only C Programming for coding UDF. Right?
Old   April 8, 2004, 05:48
EARNG
it display "c -ID:\FLUENT.INC\fluent5.5/src -ID:\FLUENT.INC\fluent5.5/cortex/src -ID:\FLUENT.INC\fluent5.5/client/src -ID:\FLUENT.INC\fluent5.5/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" inlet.c error: udf compiler: cannot execute c -ID:\FLUENT.INC\fluent5.5/src -ID:\FLUENT.INC\fluent5.5/cortex/src -ID:\FLUENT.INC\fluent5.5/client/src -ID:\FLUENT.INC\fluent5.5/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" inlet.c" please help me
Old   April 8, 2004, 11:06
ap
Yes, you can use only C coding.
Hi
ap
Old   April 8, 2004, 11:07
ap
To give more help we need to see your UDF code.
Hi
ap
UDF Problem ozgur Fluent UDF and Scheme Programming 18 January 17, 2016 14:40
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 07:51
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
