April 19, 2004, 08:39 |
turbulence problem
I tried to find the Cd of truck (external flow). The message always showed : turbulent viscosity limited to viscosity ratio of 1.000E+05 What does it mean? My simulated result is fault?
April 19, 2004, 09:16 |
Re: turbulence problem
this means that you have problems in convergence. lots of times i have seen it but after some iterations it vanishes.in your case you have AMD divergence error?IF YOUR PROBLEM CONVERGES THERE IS NO PROBLEM WITH THAT IN THE FIRST ITERATIONS.
April 19, 2004, 11:31 |
Agree with STK. You may find where the turbulent viscosity is over the limit and check if the quality of your grids is good there.
problem with UDF for (v2-f) turbulence model in fluent | artemiss1984 | Fluent UDF and Scheme Programming | 6 | January 17, 2014 05:50 |
combustion problem | mcnair | CFX | 9 | March 22, 2011 14:06 |
Turbulence model for mixing problem??? | nileshjrane | Main CFD Forum | 7 | September 14, 2010 04:57 |
Inflow turbulence problem | liuzhe1213 | CFX | 0 | May 13, 2009 08:13 |
Analyze Turbulence | Camilo Costa | CFX | 7 | December 4, 2006 11:00 |
