Run Fluent on the network
I run Fluent now on the network of the University. (I don't know if I express correctly --;;) I have problem with compiling of UDF.
For example, I meet always error massage as below, but I don't know how to correct or write the path name. Opening library „libudf"... Error: open_udf_library: A file or directrory in the path name does not exist. Error Object: #f I've written an e-mail to administrator of the network, but received no answer till this day. Is there anyone who has experience with such a case? |
Re: Run Fluent on the network
are you using microsoft vc++ compiler? or dot net compiler -- there are two seperate ways to compile your UDF in these two cases.
Thanks a lot for your answer. My computer has microsoft vc++ compiler 6.0, and I think I can also use the net compiler. However, I have little experiences of C compiling, so I want to know all two separate ways. Can you help me?
