Combustion Efficiency
Old   April 22, 2004, 15:39
Default Combustion Efficiency
Justin Rencher
Hello, I am running steady-state, non-premixed combustion with a hydrogen PDF model in a small 2-d supersonic combusting ram jet. I am trying to determine my combustion efficiency. I have been told that comparing the heating value of hydrogen with the enthalpy that is produced in the combustion model is the best way to do this. I have used the 'Reports - Surface Integrals tool to report enthalpy, but should I determine the enthalpy only across the exhaust surface or over the entire fluid zone? Am I on the right track ? Is there any other pertinent info that I may be missing? Thanks Justin Rencher
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
combustion efficiency in gas turbine combustor abotasneem FLUENT 0 June 14, 2009 08:41
Question on the calculating combustion efficiency hk Main CFD Forum 0 June 1, 2007 03:46
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
Combustion efficiency Julie Polyakh Siemens 0 July 25, 2004 02:24
