April 22, 2004, 12:13 |
Setting particle parameters
I am trying to determine the residence time of the hot gases in a steady state simulation of a furnace. I'm not sure, but I think the way to do this is using 'particle tracking'. It was posted on this site last year by jinwook, that to use this method one should do the following: "1). set particle size so that the particle should be small enough, e.g., 1.e-09 meter, and 2). density is similar or very low compared to the gas phase density". Can anyone tell me how I set the particle size and density? thanks, Mark |
Setting up reaction parameters for a 3-step oxidation mechanism of C3H8 | jose_rodrig | OpenFOAM | 3 | February 4, 2014 13:25 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Coal Particle Tracking Parameters | Michael | FLUENT | 1 | December 1, 2007 14:51 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
