turbulence at a porous jump (perforated plate)
Old   May 8, 2004, 09:09
Default turbulence at a porous jump (perforated plate)
andrew
I am seaching some advise on how to effectively model the effects on turbulence across perforated plate without creating the actually geometry.
I am modelling a perforated plate in the inlet plenum to a ceiling diffuser (ventilation outlet to a room). The plate is 1mm thich plate has 5mm diameter holes with a porosity of 40%. I know the pressure drop, so I model the perforated plate with a porous-jump. Since the turbulence is important to the flow distribution through the outlet diffuser nozzles I wish to add in the turbulent effects. Maybe I increase to turbulence intensity, but how do I do that?
Are there any useful references for the turbulence levels created by perforated plates?
thanks Andrew
Old   May 8, 2004, 09:51
Default documentation
sahraoui hichem
documentation sur la simulation numérique autour d'un profil naca0012 et
Perforated plate franzdrs Main CFD Forum 16 November 12, 2017 05:48
Need help on perforated plate with less than 2% open area sosososo1114 FLUENT 9 August 31, 2011 01:33
Perforated Plate with Porous Media giogio FLUENT 4 July 8, 2008 15:07
Modeling thin perforated plates as porous media Mike FLUENT 0 August 21, 2007 04:16
