Wall Temperature
Old   May 11, 2004, 09:30
Default Wall Temperature
CFD Newbie
When a wall temperature boundary condition is applied to a wall in a combustion simulation, is the wall forced to remain at that temperature or will fluent re-calculate the actual wall temperature?
Thanx
Tom
Old   May 11, 2004, 16:24
Default Re: Wall Temperature
Ajay
Next to the place where you set your boundary condition there is a drop box, if you choose constant then the temperature would remain a constant. If you have a scheme to evaluate the new temperature you could use a UDF and specify it here . -Ajay
Automatically update wall temperature? cresus CFX 1 December 5, 2009 05:06
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Constant wall heat flux with uniform temperature Jake FLUENT 2 September 29, 2003 11:34
About fix wall temperature in wall boundary joon Siemens 2 March 10, 2003 01:41
