May 12, 2004, 08:16 |
transient temperature distributionT(x,y,t)
hello .I have a simple 2D conduction heat in a solid(a rectangular plane surface ).(no vonvection and radiation) and I have take a stationary heat flux throught an edge as BC. I can display the stationary teperature distribution T(x,y) but I want to obtain the temperature distribution at any time T(x,y,t).DOES any body tell me what to do please???thanks
May 12, 2004, 09:30 |
Re: transient temperature distributionT(x,y,t)
FLUENT doesn't keep in memory the value of each variable at each past time step.
If you want T(x,y,t) you have to save a dat file, for example after a costant number of steps and then postprocess them in order to obtain the data you need. Hi ap |
May 12, 2004, 11:58 |
how can I do it?
hello. can you tell me how to use UDF to save the data file and post process it? and what time step you mean?? can yopu be more clear please??....THANKS.....
May 12, 2004, 12:02 |
Re: how can I do it?
you dont need a udf for taht just use file --> autosave
May 12, 2004, 12:03 |
also, i think animation feature will be really useful for what you are trying to do.
May 13, 2004, 04:59 |
I agree with co2, you can activate the Autosave option in the File -> Write -> Autosave menu.
Hi ap |
Display Modes | |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 18:31 |
set temperature on subdomain, in transient mode | nicolas | CFX | 0 | August 16, 2006 07:42 |
transient temperature field with constant velocity | Törnquist | CFX | 0 | September 16, 2003 05:22 |
stationary flow - transient temperature | Nicola | Siemens | 5 | June 16, 2003 06:44 |
