May 16, 2004, 20:15 |
minimum line length
Hi, guys I have a simple question about the limit of line length in Gambit. Actually, I tried to connect two vertexes which are 10um apart each other but I couldn't. Do you guys have any idea?
Thanks, Jay |
May 17, 2004, 13:44 |
Re: minimum line length
Everything depends on the scale you are using in the Gambit session. Why don't you work in units of um instead of e.g. meters? Gambit does not need, it even doesn't care for your length units and you can change the scale in Fluent afterwards to get the proper physical scale for your problem.
Good luck, George |
May 17, 2004, 14:33 |
thank you very much Jay
May 17, 2004, 18:33 |
FYI, the minimum line length in Gambit is 0.0001, in my experience
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
