UDF of iterations
I want to have UDF :
from 1 ~ 500 iteration , pressure-outlet=101000pa when 500 iteration finished, 101200pa. file of *.c is below, but have error. Anyone help me? ............................................. #include "udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; int iter; iter = N_ITER; if (iter < 500) F_PROFILE(f, thread, position) = 101000; else F_PROFILE(f, thread, position) = 101200; } .................................................. .. |
Re: UDF of iterations
As far as I understood, you want to have a pressure outlet b.c. of a value 101000pa when ite. lower than 500 and 101200 pa after 500 ite. I think, you won't get a b.c. like that, even your UDF runs fine, because hooking for UDF can not be made in UDF itself. You must do it manually...
good luck... Melih |
"nres" should be used instead of "N_ITER". FJ |
It is OK!
Thank you very very much! |
I am using nres in my udf, but i can tell the difference between nres and N_ITER, can you explain it? thanks |
