Reading Fluent files into TECHPLOT
Old   May 24, 2004, 01:59
Default Reading Fluent files into TECHPLOT
krishna
Hi PPl,
Please let me know, how is it possible to read ".cas" and ".dat" produced in Fluent, into Techplot, I am having a Techplot of Version 8, is it possible in this version?
Thanks in advance,
krishna
Old   May 24, 2004, 04:39
Default Re: Reading Fluent files into TECHPLOT
pratap
if you go to file and click the import it will automatically ask to load the Fluent data loaders. Which can be use to load the Fluent files. I am not sure whether it is available in tecplot 8.0 Pratap
Old   May 25, 2004, 09:02
Mazyar
Hello.
I am not sure about Tecplot 8. One way is as pratap told. I suggest the other way too: In FLUENT go to File/Export then choose File type as Tecplot, and select the parameters (pressure, Velocities,... whatever) and the boundaries or surfaces that you need. Now you will have a PLT file that you can hopefully Read it in ant Tecplot
Good luck Mazyar
Old   May 25, 2004, 09:17
Bob
The Fluent data loader in Tecplot only reads in the volume data, so if you want to plot surfaces yopu would have to go to the export and select Tecplot and then what surfaces you want and then go to Tecplot and add that data to your already loaded fluent data.
Old   May 28, 2004, 03:00
krishna
Hi Pratap,Mazyar and Bob,
Thanks u ppl for the innovative reply, it seems that in Techplot 8 it is not possible to read-in case and data files from Fluent directly, but i was able to do the same by exporting file from Fluent, with the required geometry and parameters.
krishna.
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 03:02
Reading .srp/.vrp files into Matlab Will Humber FLUENT 0 February 13, 2008 13:20
Error reading msh file into Fluent Ralf Schmidt FLUENT 5 October 30, 2005 20:00
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
Error reading 3d eccentric annulus in Fluent Parag Ramteke FLUENT 0 March 16, 2005 18:46
