user defined scalars
Old   May 19, 2004, 23:47
Default user defined scalars
ramesh
hello, Iam usind Fluent 6.1 version. when I define user defined scalars(UDS) through define-> User-defined-> scalars, iam getting an error "Error: class CxTableNT does not recognize attribute right-of" and getting a message FATAL ACCESS VIOLATION and it is saying to restart fluent. Kindly help me regarding this. Thanking You
ramesh
Old   June 11, 2004, 17:25
Default Re: user defined scalars
Podila
Hello Ramesh, First part of the error is due to becuase u are on wondows I also get it but I just leave it it does not affect the problem however u are on 6.1, so I would rather recommend u to upgrade to 6.1.22. Secondly If u can give me more info about ur problem then may be I will have some ideas. For a break what u can do is u can run the same case on linux and check if get that and I am prety sure u will have safe landing. Podila
USER DEFINED SCALARS yann Phoenics 6 November 14, 2013 08:46
User defined scalars!! Mischelle FLUENT 3 July 4, 2013 10:04
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 18:18
Source term for user defined scalars Mech.eng. Siemens 0 March 16, 2006 06:15
Naming User Defined Scalars Greg Perkins FLUENT 0 March 6, 2000 23:10
