Command line Execution
Old   June 2, 2004, 13:24
Default Command line Execution
pratap
It is possible to run the Fluent in command file without opning the user interface. Let us say I have all the files like mesh and case files also. Pratap
Old   June 3, 2004, 16:17
Default Re: Command line Execution
co2
you have all the commands that you can use without the use of mouse to click on different menus. But user interface is always necessary. Remember Fluent is a software not an operating system.
Old   June 4, 2004, 10:57
pratap
I use tecplot like that without enetering into user interface.Although tecplot is software. Thanks anyway. pratap
Old   June 4, 2004, 11:55
Arun
Hi Pratap,
I know you can run Fluent with the help of TUI commands. But I have done it only when I submit jobs in parallel using a script file. Other than that I do not know how Fluent could be run without the GUI.
Arun
Old   June 11, 2004, 04:40
venugopal
Yes, It is possible to run the Fluent without using the mouse. just you check whatever commands you have in the fluent, and they have given clearly in the fluent help. But i think it is cubersome to do like that.
Execution problems in dsmcFOAM turanc OpenFOAM Running, Solving & CFD 3 April 10, 2017 12:58
Execution termination vidhya CFX 2 April 6, 2011 07:40
How to monitor remote execution los FLUENT 0 March 6, 2010 23:28
Background execution on UNIX systems law FLUENT 1 January 3, 2006 10:53
execution sequence of ground Luc Fournier Phoenics 3 April 14, 2001 11:07
