cavitation related problem
Old   June 9, 2004, 17:36
Default cavitation related problem
Kamran
Hi everybody
I've a question which is not directly related to CFD, but here it goes: I'm trying to simulate cavitation in a suction hose using the cavitation model in Fluent. The problem is I haven't been able to find relevant data, more specifically vapor pressure and surface tensionfor the hydraulic fluid. I've been searching everywhere, even asked suppliers, but without any success so far. Now, I'm wondering if anyone knows where I can get hold of such data. The fluid used is of Dexron III type @ T=0 degree C, which is common in automotive industry (so I've been told anyway) but for the time being I would consider any "typical" or comparable data. Any help will be appreciated.
regards Kamran
Old   June 14, 2004, 03:05
Default Re: cavitation related problem
mateus
Hi!
You might have some problems with defining the vapour pressure of the liquid. I'm not fammiliar with Dexron III but for example Diesel fuel has a lot of different components and each has its own vapour pressure. simulating cavitation in water is baby stuf in comparison to what you are about to do...
good luck
MATEUS
Cavitation problem... Roland R CFX 3 September 15, 2011 10:40
Received exception: Disk full or disk related problem thekay ANSYS Meshing & Geometry 4 June 20, 2010 10:22
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Problem related with UDF for dynamic mesh Ryan FLUENT 1 April 16, 2004 06:05
Cavitation Simulation by CFD Liu, L. Main CFD Forum 7 November 1, 2000 21:26
