dpm modeling
Like Tree1Likes
  • 1 Post By barzin
Old   December 3, 2012, 04:12
Default dpm modeling
Milad Setareh
milad653279 is on a distinguished road
hi
what is difference between steady particle tracking and unsteady particle tracking?
milad653279 is offline   Reply With Quote
Old   December 3, 2012, 07:22
barzin
barzin is on a distinguished road
Hi Milad,
Well the difference is the same as the difference between steady state solution and transient solution. In Steady particle tracking the entire particle trajectory is computed until the solution gets converged. More mathematically, the Lagrangian trajectory integration time is from t=0 to t=inf. However in unsteady particle tracking, the Lagrangian integration time is between the assign values (say t=0 to 1e-06 and so on).
Hope that helps
kamyab likes this.
barzin is offline   Reply With Quote
Old   December 5, 2012, 11:34
Milad Setareh
Hi Barzin
thanks a lot. I don't understand. I think that in steady particle tracking derivative time is zero so means d/dt=0 therefore velocity is constant and it's meaningless because of Lagrangian approah is always unsteady. so why dpm modeling in fluent has steady particle tracking?
I don't understand this contradiction. please explain it.:(:(
Old   December 6, 2012, 04:25
barzin
Milad jan
Why do you think it's meaningless? plus it doesn't mean that particle velocity is constant through out the trajectory. imagine that you solve a continuous flow in a pipe. In steady calculation if the initial velocity at inlet is constant, the velocity will decay along the pipe. I think you can adapt this to a particle trajectory calculation.
Old   December 7, 2012, 07:57
hityangsir's Avatar
Y. Yang
hityangsir is on a distinguished road
His Barzin, I have a question too, assume that in a unseady problem, in the steady particle tracking, only the entire particle trajectory is computed until the end of the calculation ? that does not make sense
hityangsir is offline   Reply With Quote
Old   December 7, 2012, 11:29
barzin
Hi mate,
Sorry I did not get the question. Can u please shed more light?
Old   December 8, 2012, 04:33
hityangsir's Avatar
Y. Yang
I am sorry for that. What I dont understand is that "Lagrangian trajectory integration time is from t=0 to t=inf"?
Old   December 8, 2012, 06:05
barzin
Don't worry, I got you now, This mean the whole particle trajectory!
Old   January 23, 2013, 06:00
Default Dpm
payamfadaei
Payam89 is on a distinguished road
Send a message via Skype™ to Payam89
Hi Dears
I have a air flow which enter a cavity and exit it,I want to add some particles to the flow which has a lift and drag(I'm going to change their direction by magnetic fields)...How can I determine the diam and number of particles,velocity,permaebility and density and....
In which panel this settings exist??
Thanks a lot
Payam89 is offline   Reply With Quote
Old   January 28, 2013, 10:01
barzin
Hey Payam,
You need to have a deeper look in DPM and injection panel! I'm sure you'll able to find it.
Old   January 29, 2013, 06:33
Default Dpm
  #11
payamfadaei
Originally Posted by barzin View Post
Hey Payam,
But when I change the air by Water it doesn't work.My problem is "Fe" particles which is immersed in Water.But I'm not sure that Dpm is the model I should use!
Thanks
DPM Modeling of high Biot Number Particles Bob Stanislawsky FLUENT 1 June 7, 2017 02:15
Modeling coal combustion with DPM Amit Katiyar FLUENT 4 November 21, 2014 05:21
how to define the velocity of coal when using DPM in modeling coal gasification? harry king FLUENT 1 May 6, 2012 22:11
dense dpm riser modeling bashu FLUENT 0 October 4, 2010 12:00
DPM modeling Mohsin FLUENT 0 March 31, 2010 22:11
