Spiece model problem!!
Old   June 15, 2004, 21:09
Default Spiece model problem!!
Saturn
Hi, I have some problem about execute Fluent code for heat transfer under combustion model.
The Physical domain is shown in the attached file.The inner tube is specified as combustion model, and the heat will transfer through the wall to the outer tube, the liquid water is used as coolant.
The combustion model is OK, but I can not specified the material ¡Vwater in the Fluent solver. How should I do?
Old   June 16, 2004, 00:16
Default Re: Spiece model problem!!
Pravin Naphade
In Gambit specify the volume though which water flows as a FLUID CONTINUUM. Then in fluent specify this continuum as water.
Best Luck next time!
Old   June 16, 2004, 05:12
Saturn
But, boundary condition panel fluid type can't not set material name in spiece model. How should I set the material name in fluid panel?
k-w SST transitional model problem shanon ANSYS 0 September 21, 2010 09:00
Problem with turbulence model akonduri OpenFOAM 2 September 17, 2010 00:49
Turbulence model for mixing problem??? nileshjrane Main CFD Forum 7 September 14, 2010 04:57
Problem in Herschel-Bulkely model emad FLUENT 0 May 20, 2009 14:20
Non premixed model - combustion validation problem David FLUENT 2 October 24, 2003 10:06
