June 18, 2004, 08:51 |
negative volume
hi thank you ok in grid check appear negative volumes. how do i change these negative volumes to positive volumes ? best regard avesta
June 18, 2004, 20:56 |
Re: negative volume
You try to modify the grid size or go for different grid type. It will helps you
June 19, 2004, 06:34 |
Re: negative volume
hi thank you i will do it best regard Avesta
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
