Two phase flow boundary condition
Old   June 18, 2004, 23:52
Default Two phase flow boundary condition
bala
Hi all, For my two phase flow where gas is dispresed, in the 'phase' boundary condition, i need to specify the bubble size what is the formula to find it and if liquid is dispersed, how to get the droplet size?
Old   June 19, 2004, 08:30
Default Re: Two phase flow boundary condition
Podila K
Hello Bala,
This is not a piece of cake. If u are assuming a uniform bubble size and assuming no break up and coalescence then u can do it in the phases panel. In the boundary conditions there is an inkt condition. In the inlet condition u can select ur dispersed or the secondary phase and u are all set. There is no formula to get the bubble size in the section however all I can say is that the bubble/ drop in ur section cannot be more than the diameter of the section. But in experiemnts u can find the maximum stable bubble size and then set accordingly. It all depends on what u use for simualting. I hope it Helps Podila.
Old   June 21, 2004, 09:04
thomas
What model are you using, It exist for both DPM and eulerian a model to compute break up and coalescence. For DPM you can set it in the default DPM panel. For eulerian solver, there is a UDF on the fluent website.
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 10:54
Boundary condition for bifurcated flow jiejie OpenFOAM 12 March 3, 2011 10:35
outflow boundary condition foe flow over a cylinder Ardalan Main CFD Forum 0 April 29, 2010 13:04
How can apply mass flow rate boundary condition? Sima Phoenics 1 December 1, 2007 18:55
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
